So this is kind of strange. Got a zap yesterday and now can't figure out what happened so I am freaked that it will happen again.
I was working with a new to me project amp, a homebrew Champ(ish) build. Was sold to me as "powers on, no sound". Had two safety issues I should have addressed right away but didn't (I know, I know) 1.) Grounded prong on three wire power cord snapped off and 2.) Death cap from fuse to ground (who puts that on a new build? I guess some idiot following the schematic). Got the amp making sound by replacing V1. If I know an amp isn't grounded I'm usually super cautious about touching anything conductive.
Hooked it up to my pedal board and was playing through the Champ. Seven pedals on the board, and the 2nd one in (a vintage Maxon real tube overdrive) isn't passing sound when engaged, but fine in buffered bypass mode. Getting frustrated with that I go to turn on my regular amp and get a shock when I touch metal on that amp (I was presumably touching guitar strings with my other hand). Freaked me out, I powered down everything and did a quick assessment and I seemed fine. Disconnected the Champ and turned on the the other amp, Maxon overdrive still not working.
FF to today when I went back to diagnose what happened. I was expecting a shorted death cap and hot chassis, but it wasn't testing as shorted. Putting on a new 3 prong plug and powering on LBL and variac it wasn't making the light glow, amp worked. Reversing the hot and neutral wires at the plug to check that and it was the same. It didn't trip a GFI outlet in either polarity either. I measured the ground pin to chassis to make sure there was good contact.
Testing on the pedalboard I didn't see any voltage on guitar cable to the ground of my regular amp. Maxon pedal now working as before with my regular amp. Have not hooked Champ up to pedalboard again.
So I don't know if the Champ shocked me (though seven pedals) or if it was somehow the Maxon (which runs off a 9V supply) or if I somehow imagined the whole thing. It just seems strange.
I did go the ER afterward to get checked out, everything looked fine. I did have pain across my upper back like a muscle spasm. Still have some of that.
