Mesa Boogie transatlantic TA30
  • Mesa Boogie transatlantic TA30
    Hi
    I have a TA30 ( Rev -1A) I have never seen these before
    On start up its fine but after 2-5 mins or so then this noise starts. see picture
    Customer has fitted all new JJ tubes. didn't cure the fault.
    Remove V4 ( PI) problem goes away. Can see any issues on voltage rails, Tapped about and heat and freezer spray= nothing
    Sound_Recordings_26-08-2022-11-55.mp3
    Remove V3 = no noise... remove V2 with V3 in place, problem is there but quieter ... remove V1 no change
    Can't see any ripple on the voltage rails C-D-E-F
    Heater rail look good
    up loaded the pictures a little weird the way they have come out
    Picture below is at V3 pin 1 HI/2 channel on 40 watt, with gain between 0-1/4
    picture at bottom of page is on same point but gain up 3/4
    I can see the problem on the scope on pin 1 - 6 of V3 can also see it but lower on pin 6 V2
    Click image for larger version  Name:	IMG_20220826_110619990_111400.jpg Views:	0 Size:	3.18 MB ID:	967175
    HI 2 ( red channel)
    switched to 40 watt or 15 watt ( no issues with 30 watt)
    Master up full , tone 12 oclock , reverb off
    (switch to bypass )
    0 on gain pot = noise
    turn gain pot to 1/4 = quiet
    from 1/4 to full = noise
    ta30_131002.pdf
    Top bst channel ( green)
    Same as above but much quieter
casibom betturkey
