You want to remove WHAT???!!
  • You want to remove WHAT???!!
    Having verified this one filter cap in the power supply of the Tektronix R7623A is indeed bad, it's ALSO the tallest one of the assortment of caps. Four ground terminals, one Positive terminal, and it's nearly touching the bottom of the subassembly chassis. There's a flange that's bent upwards and the end of the power supply assembly, and the terminals of the can are long enough that there's no way to get that cap out without lifting the PCB assembly off of the power supply assembly chassis.
    After studying this Rube Goldberg assembly to realize this is the one part in the entire assembly....if it goes bad, and you called Tektronix Service Dept during the period these were in production, the peels of laughter you'd hear while the service tech on the phone stopped to put you on speaker phone for the rest of the staff to hear your question again.....I need to remove C811 to replace it.....would definitely dampen your day. The only other part in that assembly that would be worse would be having the power transformer fail.
    As I kept removing more and more parts to try and find a way to lift up that PCB so I could extract that now-desoldered capacitor, since it's too tall to just swing it out from underneath the PCB like all the rest of those caps can do.....this part had me in stitches laughing as I got further and further into disassembly to keep finding more and more obstacles preventing the elevation of that main PCB. I thought at one point, I'd need to unsolder the power transformer header....which would be another potential disaster if the PCB pads & traces firmly object to such an effort....I then found there's no header. You're looking at discrete tinned magnet wire formed upwards to poke thru the PCB. So, building this assembly was certainly a fixed procedure. No workarounds or it wouldn't go together.
    Click image for larger version  Name:	Removal of Power Supply assy-3.jpg Views:	0 Size:	1.55 MB ID:	968258 Click image for larger version  Name:	Removal of Power Supply assy-1.jpg Views:	0 Size:	1.65 MB ID:	968260 Click image for larger version  Name:	R7623A Power Supply-2.jpg Views:	0 Size:	2.02 MB ID:	968262
    Click image for larger version  Name:	R7623A Pass Xstr Board-1.jpg Views:	0 Size:	1.72 MB ID:	968264 Click image for larger version  Name:	R7623A Power Supply-4.jpg Views:	0 Size:	1.44 MB ID:	968266 Click image for larger version  Name:	R7623A Power Supply-5.jpg Views:	0 Size:	1.35 MB ID:	968268
    So, another afternoon spent finding obstacle after obstacle in trying to get this assembly apart. The rear fan/BNC Output PCB assembly housing had to come off, all of it tethered to points yet to be found and such....and still no closer to a solution to lift that PCB up. It appeared I'd have to unmount the power transformer from the chassis. Only access to it requires further panel removal, to which the fan has to be removed, then another cluster of parts that indirectly mount to an upper transformer core screw, of all things. WHO thinks these things up at Tektronix???!! No wonder they're so bloody expensive when new. Date codes indicate the caps were produced in 1984 I found an Avery label stating NEW #933110 5/3/85.
    After removing the fan, that gave me access to more panel screws, and got that subpanel off. Then found a wire from the top of the Filter PCB down to a Thermal Switch on the bottom of this pwoer supply chassis was taut, so it had to be unsoldered too. Finally:............
    Click image for larger version  Name:	Disassembly of Power Supply-4.jpg Views:	0 Size:	1.91 MB ID:	968270 Click image for larger version  Name:	Disassembly of Power Supply-1.jpg Views:	0 Size:	1.70 MB ID:	968272 Click image for larger version  Name:	Disassembly of Power Supply-3.jpg Views:	0 Size:	1.17 MB ID:	968274
    Click image for larger version  Name:	Disassembly of Power Supply-2.jpg Views:	0 Size:	1.48 MB ID:	968276
    All that work to get a simple filter capacitor off of the PCB. I did find that I can install a 35mm dia 10mm-L/S Snap-In Cap onto that PCB, though the neg lead would be fitting into that LARGE hole near the edge of the board, where the original cap has the one wide solder tab. I'll work that out when I get the replacement cap. I looked at this using that short Black 15,000uF/50V cap, and for a brief moment thought maybe I'd just solder that in. NAW! Leads are already too short, and don't want to have to do all this over again. I can wait a few days for a new part to arrive.
    And, it looks like I won't have to install any jumpers to restore circuits that the ground leads of this bad cap were needed for.
    I haven't yet pulled my Tek 7633 apart. THAT is the instrument that has failed, no longer having any trace image, nor any indication of the Storage System working. Figuring it's a power supply problem, I brought this instrument in to educate myself in how to extract the power supply.
    I just looked at the back of the 7633 scope, NOT a rack-mount R7633, and see it's NOT really built this way. Though uses the same power supply assembly, but totally different mechanics with a different fan, so this might have been an exercise in futility. Hope not. More reading to do, but I now know how to replace this stupid cap!!
    https://music-electronics-forum.com/...lloscoe-failed
    This is the rest of the ordeal in trying to learn how to fix that Tek 7633 scope thus far.
    If you have trouble finding a replacement cap let me know. The surplus electronics business near me buys tons of stuff from Tektronix since they are local. Maybe a longshot but I wouldn't mind looking for you.
      Hey, thanks, glebert! I just looked in the service manual for the 7603 scope....found it has the same power supply assembly as the 7623A and the 7633 scope (that failed), Not unlike Detroit. Loads of car models, only a few engines that they build everything with.
      The last photo in the previous post shows that 14,000uF/25V buss cap...made by Sprague...Tek's P/N for it is 290-0581-00 14,000uF/25V 85 deg C rated. Four Gnd terminals (one a twist-blade), one positive terminal. 35mm dia nominal, 80mm tall (I think....will check when I get into the shop in around an hour).
      I was tempted to just make a retrofit on the 15,000uF/50V used snap-in electrolytic cap that I also tested both on my bridge and with the ESR 5kHz 20VP-P square wave source. It responded much like the pair of 9600uF/30V buss caps on the +15V unregulated side of this particular power supply in the system. Maybe you'll find this part.....is a long shot, but, I'll hold off to see what you find. I'd rather use the correct part than a substitute as the snap-in part would be. Date code on that part I removed is 8452 (1984, 52nd week)
      Click image for larger version  Name:	image.png Views:	0 Size:	172.1 KB ID:	968295
      I just checked this part....it's 91mm tall, not 80mm. looks like the Sprague part number is 68D10489
      For the time being, I've soldered that used 15,000uF/50V snap-in buss cap so I can put this power supply back together. I can still remove that assembly, and there's enough room to unsolder that part for either the correct part or a new retrofit. I'm going to need the bench space, and can't leave this all apart. I'd never remember everything to reassemble it, so gotta do this while it's still fresh in mind.
      Thanks!
