Stromberg Carlson AU-42 Restore and Loud Squeal
  • Stromberg Carlson AU-42 Restore and Loud Squeal
    I am trying to resurrect this AU-42.
    I have replaced every cap with the exception of two domino style caps, C5 and C8.
    Also installed a 68K grid stopper at V1.
    V1 is a 6SF5
    V2 calls for a 6J5 which I do not have, I am using a 6N7 and have jumped the grid pins 4 and 5 to make the 6N7 work.
    After completing all the work I am hearing a very high pitch and loud squeal with all pots at zero.
    I have scoped the output.
    Suggestions greatly appreciated.
    Technical manual in pdf below.
    Thank you, MarkO
    radiomuseum-stromberg-carlson-co-amplifier-au-42-2482481.pdf
ID:	968811 Click image for larger version
ID:	968813 Click image for larger version
ID:	968815 Click image for larger version
    Just recalled that I should check for OT primary wires reversed.
      Yep! Certainly worth a try, doesn't take long.
      However, if OT wiring wasn't changed can't see why it would start squeeking due to incorrect polarity at that point. Sometimes old tubes set up a squeal, also insufficient power supply filtering.
      Domino caps? Sometimes one has been at the root of some problems I've encountered. There was one x-pensive boo-teek tweed a customer brought, the builder used all new, good parts except for one domino which he reckoned was vital for the "vintage tone." Amp sounded like a hurricane with whooshing wind and crackling lightning. It was the domino. Swap in a competent cap and now the $3000+ boo-tiki sounded proper.
        I had a used pair of Made in China Coke bottle 6L6GC that I had never tried before and was suspicions of. Swapped output tubes and the squeal is gone.
        I am left with a -57 db 120 Hz hum. Do I need more filtering?
        Specs call for 40 uF and 30 uF. I installed 47 uF and 30 uF.
        Can 120 Hz hum be caused by mis-matched output tubes? Though these same output tubes sound fine in my AU-34 amp.
          Treble pot does not seem to do much to my ears. There is a 1M pot with a domino 500 mmF cap. Any suggestions to make this tone control more effective?
