What i mean is if you have several 12AX7s of the exact same model and try them all in circuit, is there a measurement u can check that would tell you which ones are stronger or in NEWER condition? I have a bunch of old 80s chinese ones that are one of my fav 12AX7s and i know some have many hours on them and some much less so. So i'm wondering if theres a way to check.
Is there a way to test 12AX7s in circuit ?
As I seen it, all that matters is in circuit performance, whatever some valve tester says seems immaterial. I just check that each section has reasonable gain and isn’t hissy, hummy or microphonic.My band:- http://www.youtube.com/user/RedwingBand
- Likes 3
Originally posted by Mick Bailey View PostYou could set up an amp with a steady fixed signal input (say, 1khz) and measure the AC output of the first preamp tube. Stronger tube=more output. Just a relative check. It won't tell you the age of the tube, though.
DC voltages in the amp will tell if the tube works, scope measurement can tell about gain and clipping characteristics.
None of these will show if the tube is noisy or microphonic nor how it really sounds.
I don't think there's any tube test that reveals tube life left.
This might be interesting (thanks to nickb):
https://bmamps.com/v01/home/techie-c...parison-tests/- Own Opinions Only -
- Likes 2
Ok, well i hadda ask. I tried all of them and aside from one that was faulty they all sounded close, a few slightly different. But those old chinese are just such neutral sounding tubes that i find them to be the best for most amps overall so i was hoping i could determine how many i really have that aren't old and worn.
Originally posted by Mick Bailey View PostYou could set up an amp with a steady fixed signal input (say, 1khz) and measure the AC output of the first preamp tube. Stronger tube=more output. Just a relative check. It won't tell you the age of the tube, though."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 2
I'm familiar with the theory and data, so I won't argue with you and concede your point. I'll just say that my ears have said otherwise on several occasions."I took a photo of my ohm meter... It didn't help." Enzo 8/20/22
- Likes 1
I think tube parameters are usually measured in the tubes normal linear range. I've never seen data on what happens when they are pushed beyond there. Maybe that's where some frequency differences could come into play?
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 2
To expand on what mozz suggests; some old tube testers had a 'life test' function that reduced the heater voltage considerably, the idea being that as a tube ages the emission drops. Reducing the voltage below a certain level gives a clearer indication of how much the emission has dropped, which may otherwise appear OK at the full rated voltage. It's fine as a comparative test, though is dubious in determining the actual remaining life in a tube. My emission tester drops the voltage to 5v and I think 4v. Using a reference tube gives a benchmark. In practice, after playing around with the tester I packed it away and never bothered with it again - I'm not too concerned about tube age so long as a tube sounds good in an amp.
- Likes 3
Originally posted by g1 View PostI think tube parameters are usually measured in the tubes normal linear range. I've never seen data on what happens when they are pushed beyond there. Maybe that's where some frequency differences could come into play?
And on the forward biased Vg-k characteristics. eg a sharp transition into grid conduction may tend to cause a greater proportion of higher harmonics than a more rounded transition.My band:- http://www.youtube.com/user/RedwingBand
