Framus CS
  • Framus CS
    Hi!
    This amp came making some crackling noise and I thought it was some preamp tube.
    In fact, when I pull the reverb tube, the noise goes away, so I have replaced the tube ( 2 times ), but the noise continues.
    I have the reverb cable disconnected and the switch off.
    Even with a new tube socket the problem remains.
    What should i do next?
    If noise vanishes when you pull V5, that implicates the supporting components R30-33 and C16,17. The plate resistor R31 would be my first suspect.
    http://amps.monkeymatic.com
      Thank you for replying. I'll check these parts.
      I also notice very small DC on the grid, 50mV, could this be the cause?
