Gday all,
Brains trust time,
Stumped with this one to the point it has to be something obvious I'm missing.
Amp was in for blowing fuses, fixed that, but noticed when testing that the Bright channel has a parasitic osillation all thru the waveform out of the vol pot, "caused' by the 100pf bright cap.
1khz 200mv test signal, is as clean as, on Ch2 at same point with same cap fitted.
Clean signal out of the valve plate thru the coupling cap.
Not the valve, even swapped the Grid/plate inputs to v1, so not the input network. Ran a shielded wire with 38kR direct to valve pin to no avail.
Not the tremolo network as far as i can see. (I disconnected input to V1)
Not the plate resistors.
Not the following stage.
I've fiddled with lead dress as much as I can without ripping it all apart.
Bottom line is that the amp works, although the out put is not as "nice" as I'd like it to be, pointing towards that issue.
Out of shear frustration i thought I'd ask here if any one had had similar issues.
Ive worked on tons of these circuits and never had an oscillation like this, at this stage of the amp.
cheers
Gav
Brains trust time,
cheers
Gav
