Blackstar HT Club 50 schem?
  • Blackstar HT Club 50 schem?
    Hey all,
    I have the schematic for the HT Club 40, is there one for the 50?
    Or is the 40 close enough? It looks pretty similar.
    No signal after the tube preamp, power amp works fine, no FX send out or return.
    Looks to be that PIC chip that does the switching from other posts I've read.
    I'll check for proper voltages to it etc.
    Thanks.
    I would say they were one and the same.
    Have you got HT on the pre amp valves?
      Yeah, there is signal through the tube stages of both channels at TP3 and 4, I need to check TP5 and 6 as there is no signal to FX out.
      Thanks. blackstar HT-Club 40.pdf
