Crate CA30D No Output Help
  • Crate CA30D No Output Help
    I have a CA30D with no output. The speaker pops when turning ON so I think the output side may be okay.
    I started checking the input path and noticed something odd (to me) about the TL074s in the path. The + and - 15V supplies are opposite the schematic and TL074 pinouts. I am seeing -15 VDC at pins 4 and +15 VDC at pins 11.
    Schematic shows otherwise. However there is continuity to D1 and D2 that supports the readings I am seeing. So I am confused...
    The TL072 further down the path has correct power supply polarities.
    Attaching schematic.
    Thank you! MarkO
    crate_ca30d_07s287_sch.pdf
ID:	972603 Click image for larger version
    How about at D15 cathode and D16 anode?
    And I hate to ask, but no chance probes got plugged into wrong ports?
    edit: also, 072 has opposite of 074 on pin4.
      Read anti clockwise from the top;
Name:	Screenshot 2022-11-07 at 21.43.50.png
        TL072 pin 4, - 16 VDC
        TL072 pin 8, + 16 VDC
        D15 cathode, + 16 VDC
        D16 anode, - 16 VDC
        I hear you... My probes are in the right place and are never removed from the meter.
          Argh.... I had it backward. Sorry guys. VDC are correct.
          Okay, back to my no output mystery....
            ok. I have signal up to R10. C13 may be a problem as I see nothing after that.
            C13 re-soldered. Amp is working!!!
              You were drowning in a glass of water
                Yes I was.
