Ghost Note Causes
Originally posted by drewl View Postvarying tone controls can alter the waveform
I can get around 20vac into 4 ohms clean, above that waveform peaks start getting ripples on them
RMS This thing is a beast putting out like 150 watts peak.
I ran a preamp with guitar straight into the PI, still ghosted, tried driving each output tube grid with an amp but couldn't drive it enough to ghost.
I have to ask the owner if he left the output transformer connected in any way when he tried another OT.
The plate leads look like they were unsoldered, but the center tap HV doesn't, don't know if that would make a difference.
Originally posted by drewl View PostRMS This thing is a beast putting out like 150 watts peak.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Standard Marshall wiring from the PI through the power amp.
It does have some "mystery mod" that takes the master volume signal, runs it through a "cupcake" of goop and sends a boosted signal back to the bass pot.
The "cupcake" of goop has high voltage DC going into it.
I disconnected this mod but ghost notes are still present.
I tried another OT, no dice.
Thanks all.
As long as the power amp (including PI) is well balanced, it has good ripple rejection regarding B+, screen node and bias ripple.
This is likely to change when it's overdriven and grid signals get asymmetrical (duty cycle shift and blocking distortion).
So make sure the screen supply has low ripple and the bias is clean.
Could even be a shorted choke.- Own Opinions Only -
Originally posted by drewl View PostThe extra gain stage is inserted before the cathode follower stage.
switching it off, removing the tube makes no difference.
The tubes are balanced within a couple mv, and I tried different ones.
Increasing the presence increases the ghosting/oscillation.
Signal hitting output tube grids is nice and clean, after OT it looks like this:
