I apologize for bringing this up again, but in my searching I wasn't able to find a solution to my specific problem. When I turn on the amp with all tubes installed, the relay clicks on and off and doesn't stop, although it slows slightly after a few seconds. The green light comes on in this condition. When I test the amp with the power tubes removed the relay clicks on like normal and all the voltages look correct.
I haven't tried swapping the 12AU7s yet, but I have replaced some bulging caps in the power supply and the 10 ohm cathode resistors just cause. Also replaced Q1 and tested all the components on the AC term board. All 6550s are a new matched set.
Does anyone know what condition could be causing the relay to go nuts when turned on with the tubes in but act fine with them removed?
using schematics found here:
http://www.tangible-technology.com/s...g/SVT/Classic/
