I just tuned up this HRD. Checked all HV, all tube pins at the board look good. I saw a slight burn area at the power resistor of V4 but HV is there on the tube pin. Someone had replaced the OT.
Everything seemed good. Played well on the bench but I did not play for very long.
Buttoned it all up, played for a few minutes and then the noise started (lots of crackling sounds). Turned all volumes to zero, still noise. Disconnected the guitar cable, still noise.
I believe these are known for having issues.
I will open it up again very soon and start to chopstick, etc.
Thought I would check in for any suggestions.
Thank you, MarkO
Attached schematic I am using.
Fender-Hot-Rod-Deluxe-Schematic.pdf
Thank you, MarkO
