Hammond have a primary magnetising current limit of 400mA for that PT https://www.hammfg.com/files/parts/pdf/290D2X.pdf
Troubling idle current draw from unloaded 60's Super Reverb
I don't think the iddling, no loaded current have some in common with magnetising
Iimit current. Think more thermal characteristics do a difference. I don't have the knowledge but always wonder why smaller trannies are made with more turns per volt ? And my beliefs is they just doing another compromise to deal with thermal abuse which the bigger ones may support easier. ...just my thoughts.Last edited by catalin gramada; 11-16-2022, 12:59 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
If primary magnetising current isn’t the primary current with the secondaries unloaded, what is it?My band:- http://www.youtube.com/user/RedwingBand
You're talking about a curent magnetising limit meant premagnetisation current which is tens time more as nominal regime curent. That I understand.
Supposed is a 400mA primmary rated. We don't know what kind of limit it is. What happen if we draw more? It overheating ? It saturate ? I thought is a time function in respect was rated for a infinite working time. For short periods of time it may use over rated currents without any problems , and think not saturate at all. That lead me as conclusion is a thermal deal.Last edited by catalin gramada; 11-16-2022, 01:29 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
I think pdf64 is right here.
While 400mA looks rather high, it would explain the no-load current draw and that the PT still doesn't start to smoke.
Magnetzing current is largely reactive (inductive) and reactive power doesn't heat the transformer.
It's value is mainly determined by the primary inductance.
I've never seen a PT datasheet that specifies a max. saturation current.Last edited by Helmholtz; 11-16-2022, 04:11 PM.- Own Opinions Only -
- Likes 1
I didn't understand the whole sentence as only tubes (and lamps) have filaments.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
Originally posted by SoulFetish View Post
Okay, what I mean by that is. With no tubes or lamp installed, there (should be) no load on the filament. The winding should be an open circuit.
Still a transformer can't have a filament.- Own Opinions Only -
Originally posted by catalin gramada View PostYou're talking about a curent magnetising limit meant premagnetisation current which is tens time more as nominal regime curent. That I understand.
Originally posted by Helmholtz View Post...Magnetzing current is largely reactive (inductive) and reactive power doesn't heat the transformer...
Unloaded PTs do tend to warm up somewhat though, so it seems like there must a 'real' component to the primary current?My band:- http://www.youtube.com/user/RedwingBand
- Likes 1
Magnetizing current Iex does not depend on the load.
It would only increase at a higher mains voltage or a lower mains frequency (like 50Hz instead of 60Hz).
For the manufacturer a higher than rated Iex would indicate e.g. a poorly assembled core having increased effective airgap.
So it is an acceptance criterion for QC.Last edited by Helmholtz; 11-16-2022, 06:10 PM.- Own Opinions Only -
- Likes 1
Originally posted by pdf64 View PostUnloaded PTs do tend to warm up somewhat though, so it seems like there must a 'real' component to the primary current?
The brand new replacement was exactly the same as far as unloaded current/heat.
However, I never heard back from the owner, and for a very costly part, I thought I would have if he didn't hear a difference in the hum level.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
- Likes 1
The core losses cause a phase shift of the magnetizing current resulting in an active/real current component.
Core losses can be modelled by a loaded secondary which adds a real current to the reactive magnetizing current.
Percentages vary with design.
A PT may have 5% core loss, meaning that the core would be heated by 13W with a 260W transformer.Last edited by Helmholtz; 11-16-2022, 08:20 PM.- Own Opinions Only -
- Likes 3
Originally posted by g1 View PostI had a boogie that the customer wanted a new PT installed. Dual Rect. I think. He said it had been humming badly though it seemed fine to me. It was all good except it got pretty warm even unloaded, and the unloaded primary current seemed high. I went along with it as the customer insisted it be replaced. I was hoping the new one would idle cooler unloaded, and less current, and the owners suspicion would be proven correct.
However, I never heard back from the owner, and for a very costly part, I thought I would have if he didn't hear a difference in the hum level.Last edited by catalin gramada; 11-17-2022, 07:21 PM."If it measures good and sounds bad, it is bad. If it measures bad and sounds good, you are measuring the wrong things."
- Likes 1
Just wanted to follow up. Turns out everything worked out okay. The PT was probably on the high end of acceptable no load current. After reinstalling all the tubes and setting the bias, the loaded transformer was operating as expected.
This was another super which sounded fantastic, by the way. With the right compliment of 4 x 10" speakers, there is no Fender which sounds better than a Super Reverb, IMO.If I have a 50% chance of guessing the right answer, I guess wrong 80% of the time.
- Likes 4
