EVH 5150-3 issue
  • EVH 5150-3 issue
    Ok.... ive got 2 scems ..1 is a 2006 and other is a 2011 - I think ?? My amp has a 2014 pcb. This amp is a 50w combo with 6L6 and doesnt have the concentric pots.
    So.....When im on BLUE or Green mode.......the Gain pot of Ch3 RED , affects these 2 channels...it should not. Red channel operates normal.
    I suspect Q1 ..it looks like a Mute . J113 transistor . What do you guys think ?
    I can even find Q1 in the amp.......frustrating...
    WELL-----i found that Q1 is REMOVED............wow.
    i am looking thru my bin and found a J111 ---that should work yes ?
      Installed a J111... green)clean) is ok....Blue CH is still affected by ch3 Red Gain pot...
        J111, 112 and 113 are very similar and should be interchangeable according to onsemis data sheet.
          The cutoff voltages are different and given the range of variation within Jfets you could get unexpected operation. A J113 may work as a substitute for a J111, but not necessarily vice-versa, depending on the specific device cutoff voltage.and the circuit voltages. Check the circuit VGS to be sure.
          EDIT: Looking a the schematic and the voltages should be fine for a J111 in that position, though I wonder why Peavey chose to use a J113 when elsewhere in the amp they used J111. You'd think that they'd be wanting to rationalize parts.
            That really makes no sense.
            Green & Blue are a totally separate circuit from Red.
            If Q1 is working (mutes Red) for Green, then it should also work for Blue.
            Something else must be amiss.
              II dont know if this helps , but when on the Blue ch. , turning the Gain pot of Red ch. it acts like a wide sweeping treble...not a gain control . I will post a video of me turning the red gain .
              https://youtu.be/SCV2IZcHkFA
              Could it be Z1 / Z2 ? Maybe a relay ?
                So Blue is not ok.
                Good.
                Q1 circuit is still the prime suspect.
                It's not muting the Red channel.
                What is the gate voltage doing when Red is Off & then On?
                I would check every part & connection of that circuit.
                  Gate is 0.4V blue mode , -07.1v Red
                  i now have a 2011 evh here to compare on the bench
                  The readings are the same on both amps at Gate of Q1 .
                  I took readings on both amps at Z1 / Z2 . heres a pic of that--the bad amp is highlighted =
                    Verify that 1 is functioning.
                    Pin 2 at V2 A should have no signal when Red is off.
                    If so, then the issue is before that.
                      amp on in Blue mode , V2 - pin 2 measures 1mV dc , and .06VAC
                      clipped out Z1/Z2 = no change
