Marshall Haze 15 channel switching issue
  • Marshall Haze 15 channel switching issue
    I have a Marshall Haze 15 with a channel switching issue. The channels switch with the footswitch but not with the front panel push-button switch. Assuming the footswitch and front panel switch use the same circuit & relays the issue would be the front panel switch ( I would guess). If anyone has dealt with this issue or could offer some info or suggestions I would greatly appreciate it. Thanks in advance!!
    I hit the panic button too quickly!!! Two of the three footswitch jack contacts were open and that was preventing the front panel switch from working. I closed the contacts up and cleaned them and now the front panel channel switch works just fine.
    casibom betturkey
