Ive got a Marshall Origin 20 here with a nasty buzz/hum. Ive been chasing it for a long time and now I finally have a scope . I modded the amp according to Headfirst amps and its basically converted to a jcm 800 preamp. The amp sounds very good but....the buzz.
So , id like to give you all the info and Ill post scems and pics / video .
'The buzz can be killed with the master volume so i assume its before that .
Ive swapped tubes , and pulled the pcb out a couple times to inspect. ALL grounds check good with meter as do ALL shields on the cables . All pots are grounded as is the main Pcb .
I know its something with the mods. Ive also clipped a wire to ground and touched all ground points in the preamp
Ive went back and watched the mod video several times and everything looks good.
Here is what Im seeing on the scope ( will post a pic of V2/ Pin 2 )
Input jack and all of V1 sine wave is smooth and flat
V2
pin 1 noise on scope
p2 Noise (this is where its loudest on scope )
p3 noise (this goes to tone stack )
p6 noise (tied to pin 2 )
p7 NO noise
p8 No noise
so here is the stock scem , the hand drawn new layout , a video of the buzz
you will see the stock preamp is kinda funky as far as a Marshall
Im new to O scopes so maybe you guys can help me pinpoint the issue
https://youtu.be/bBq2114QDtc
![Click image for larger version
Origin_20_Main_PCB.pdf
V2
p7 NO noise
p8 No noise
