I am experiencing a fairly pronounced hum in my Deluxe Reverb and would really appreciate some suggestions. I replaced and biased the power tubes a few weeks ago, but the hum is new. The hum is loudest using the first input of the reverb channel, which is the input I always use. The hum is reduced significantly when I use the second input of the reverb channel. If I disconnect the reverb it has no effect on the hum. If I plug into the normal channel, the hum is much less, but it is somewhat louder in the first input vs. the second input of Channel One. Varying the volume affects the volume of the hum. I swapped out all of the preamp tubes and they all seem to be OK, no impact on the hum.
I tried cleaning the input jack with no improvement. Any ideas? Can I assume that the imput jack needs to be replaced?
Thanks,
Lamar
Thanks,
Lamar
