Hi, all.
Another day, another strange amp issue. I've been working on many old amps for a currently defunct amp co, whose og owner has passed on. The new owner has supplied me with a bevy of old prototypes to fix and it seems every 1/20 presents an interesting issue I've not yet encountered. This particular amp is working well with one exception.
During warmup (no standby switch) the plate voltage will increase to 380vdc, then drop down to 320vdc, when there when an audible pop will accompany the voltage instantly rising to 384vdc - theres a .x volt wiggle here. Meanwhile, the screen supply (at cold start) jumps to 400vdc, then steadily drops to it's destination of 380vdc.
All of these amps are built in true proto fashion and it’s become obvious the original owner/engineer worked for Leo (which he did). The amps are a tac-soldered hodgepodge of re-appropriated eyelet boards and old school astron, ajax, and blue/brown turd caps from the 60-70s. It's as though the vintage component storage facility blew up next to this amp. All of these which have failed have been replaced. Resistors are great. I'd suspect the JJ kt77's at this point, but both are on the warmup roller coaster. Have any of you seen this type of behavior before? TIA for looking.
Best,
fd
Best,
fd
