The LED here is just a power indicator and the series dropping resistor is plenty big. No circuit is dependent on it's voltage drop. As long as you can see it light up, color and voltage drop don't really matter (within reason). Also, if you have it disassembled and don't want to measure voltage on the pads, the schematic shows that anode goes to ground, so just use your meter to see which pad is ground and solder anode to that pad. Sure you can depend on long lead anode and circuit board markings, but you can also verify everything with a DVM so that you don't end up taking it apart again. That's sort of what meters are for.
Simple question I hope
Originally posted by Oldmactech View PostThe original LED was clear.
The new LED is white and it seems the voltage drop is higher on solid white.
Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostAs far as the color names go, it refers to the powered up color. A clear one that lights up white is called white. A clear one that lights up red would be called red. And a LED that looks white unpowered is likely called frosted white.
nosajsoldering stuff that's broken, breaking stuff that works, Yeah!
Originally posted by Oldmactech View PostD1 on the schematic shows the off center line on the PCB, the line indicates the cathode side?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by Helmholtz View PostThanks. Looks like a white LED.
In-circuit current is about 30mA and LED should be rated for more than 100mW.
Originally posted by Oldmactech View PostHate to be a newbie but would be interested in the science behind this LED.
- Likes 1
Originally posted by Pixel View Post
White LEDS actually emit blue light and the blue light excites phosphors that emit the missing colors to make the light appear white. If you look at a white led you can see the yellow phosphors inside.
Forward voltage matters regarding LED power consideration.Last edited by Helmholtz; 02-12-2023, 05:22 PM.- Own Opinions Only -
Looked up a few Edgelec (a Chinese brand) LED data. Seems the white ones typically have a current limit of 20mA and a power limit of 60mW.
Means not suitable here.
You might try to increase the value of R51 to 2.2k to accommodate your LED but brightness will be lower.
Better get an LED from a reputable brand like GE, Cree, Nichia, Philips, Osram etc. having a suitable specification (including some safety margin).
I wouldn't buy from a source that doesn't provide a complete specification.Last edited by Helmholtz; 02-12-2023, 11:21 PM.- Own Opinions Only -
Here's the datasheet from the Mouser site:
https://www.mouser.de/datasheet/2/72...NN-3011984.pdf
Current limit (25mA) is too low. You need to increase R51 to 1.8k or even 2.2k.
Increasing R51 lowers brightness but increases reliabiliy.- Own Opinions Only -
Originally posted by Oldmactech View PostOrdered these from Mouser. The Mouser rep wasn’t able to assure me it was correct for my application.
C512A-WNN-CZ0B0152
Cree LED Standard LEDs - Through Hole
You won't notice a difference in brightness between the 1.8k and 2.2k resistor so go with the 2.2k for longer life. It is puzzling why Peavey didn't go with a 20mA part. Verify that R51 is really 1.2K as the schematic indicates. Maybe it is a typo or they changed the value in production.
- Likes 1
