I posted a few weeks ago about some troubles I was having with a heavily modified 1981 Carvin X-amp with a rev B circuit board that did not match schematics. I did my best to identify modifications and reverse them, and I feel confident that the amp is close to how it left the factory. While doing so, I circuit traced the entire amplifier and updated the existing schematics to reflect the Rev B circuit board.
I have one question that outstrips my admittedly limited audio and tube circuit knowledge. The negative feedback resistor went from 22K in the earlier version to only 1.5K in my amp, and I'm left wondering if that too was an owner modification or if it was a sensible factory change. I've documented all noted changes in the attached schematic(s). The values shown on the earlier, revision A schematic are indicated in red. Current values are in black.
Carvin_x100b_1981_Poweramp.pdf
Carvin_X100b_1981_Preamp.pdf
