I'm trying to repair the above Studiomaster 908 and would appreciate some advice, please.
My friend in our band purchased said Studiomaster online (working ! ), when he returned home he decided to test his newly acquired mixer by injecting a tone in each input in turn and checking the signal lights worked. I should mention at this point that he did not connect any speakers. All went well until he tested channel 5 and the smallest movement of the channel slider pushed all the signal indicators to max and a loud internal bang was heard.
On inspection the bang had not only destroyed the four MJ15003/4 power transistors but also TR10,15, D1,4,5 and actually splitting the case of TR14.
Sorry for the pre-amble but here's where I need the advice. Having looked at the circuit it looks like the output voltage swing had enabled D11 (DIAC) and hence made TR21 (TRIAC) conduct and shorting the speaker output and blowing the transistors. Having never seen this type of overload circuit before it does seem ODD. Am I wrong in my assumption?
Regards Geoff.
Regards Geoff.
