Hello all
Let me tell you the story of this one
Customer has 2 of them , One of them had a strange almost slight bad speaker fault, He has changed the speaker still the same. Bring both into me and i test both side by side The faulty one does have this problem and all tested with different basses and speakers inc my test speaker,
Di out checked ok,
Headphone out checked ok,
Gallien-krueger_MB150-III,_MB-150S-III_Preamp_Service_Manual.pdf
Checked the Return with a signal and the problem is there
gallien-krueger_mb150-iii_pwramp_sch.pdf
I know this is a strange fault and i have tried to explain to customer about finding it and i wouldn't worry about it, Nobody will hear it while on stage , But seems to be hell bent on getting it repaired and he adores the amp
2023_01_25_10_19_43.mp3
The fault
after about 1-2 min of power on you can hear a slight distorted decay on the note you have played. E and A string are the only ones that come up with the fault
E string 5th and 7th fret and A string 5th fret ( Audio clip is A string 5th fret )
I have spent time to sort of a couple of issues with the pre amp , most pots Testing i'm 95 % sure its the power amp
Unable to use the scope on this fault,
Before xmas i have a chat via email with a GK tech , at the time i was pretty sure it was the pre amp at fault. But i have changed my and now believe its the power amp. I have since lost the email , deleted on a monthly clear out![Thumbs Down](https://music-electronics-forum.com/core/images/smilies/icon_tdown.gif)
I do remember the tech saying about the driver transistors .
So my next plan was to change all drivers
Does anyone have any thoughts on what to do next
100% not the speaker or bass or vibration from the cabinet!!!!
Di out checked ok,
The fault
