Marshall Valvestate vs265 keeps blowing fuses
  • Marshall Valvestate vs265 keeps blowing fuses
    Hi all, i have an amp that recently had reg1 and reg2 replaced and two small capacitors as there was no sound. Then when i got it home it worked for half an hour until i turned on overdrive with foot pedal and then blew shortly after. So i got some new HT 1 amp slow burn fuses. But keeps blowing the fuse as soon as i turn on the amp. i can read schematics and can solder but havent got a clue on how to find the broken components in a methodical manner so i don't have to test every component. Has anyone got any ideas of how to proceed with this? What do i check first?
    Please post a link to schematic.
      I don't think the site will let him upload files to the site until they have a certain number of posts first. So Tony let us know if this is the correct schematic.
        You say 'HT', but do you mean the mains fuse? It's the only fuse I see that is 1A slow. And it is only 1A where there is 230V mains voltage.
          I'd start by checking resistance from all power supply outputs to ground and see if you detect shorts on any of the supplies. You say 2 small capacitors were replaced. Which ones? Were they installed oriented correctly if electrolytic?
            Yes the mains fuse and i'm running 230v in uk
              the two little capacitors next to REG1 and REG2
                C9 and C10 which are 100uf and yes it appears they are right way round
                  How would i know if there is a short and do i test with power adapter on?
                    I would check Q15/16/17/18 the output transistors.
                    Check you have no short between pins 2 & 3 of each transistor. Click image for larger version
Name:	Screenshot 2023-01-27 at 18.52.04.png
                      I don't mean to be rude at all, but asking those questions probably means you should take the amp to a qualified tech. Please don't take offense to that statement, but you could do more damage than good if you lack some basic electronics understanding.
                        I've checked the transistors and two had blown and one resistor. But now i'm i want to know where is pulling excessive current to fry these, maybe Opamp?
                          Yeah probably but can't afford it
                            Who replaced the regulators in the first place? They should take care of it. When you try to fix it yourself they will tell you it's your fault.
                              Can't seem to get in touch with them anymore
