Hartke 3500 Hissing, Crackling
  • Hartke 3500 Hissing, Crackling
    Hi all, I have a problem with my old workhorse Hartke 3500 bass head. I have been using it in our practice space for several years and occasionally gigging with it. The only work I have done on it in the past was to re-solder all the power transistors when I started getting crackling, a known problem on these amps.
    A while ago I went to practice and turned it on, and got the sounds that you can hear in the linked video. Schematic attached also.
    -Loud hissing and buzzing , mostly on the solid state channel, with no instrument plugged in
    - Known good tube installed in tube channel
    - no sound from any instrument when it is plugged in
    - no change when a cable is in the effects loop
    - noise changes when the EQ is in
    - sound is changed when the contour and volume knobs are turned
    - no noticeable burned components or bulging caps, main transistors do not get hot
    I am fairly ok with electronic repair, I can measure voltages and solder pretty well, I am looking for some advice from anyone who has repaired this particular amp and may be able to assist me on what to check first.
    Soliciting advice on the problem with this amp and what to check to begin fixing it.
    My guess is a bad connection to the graphic eq, I would clean the switch and faders with appropriate cleaner/ lube.
      Also check solder on any connectors of the front panel board. We used to do a lot of connector resoldering on those amps.
