Hey Folks
Sometimes what seems simple I can turn into complexity.
I have a request to modify a Fender Super Reverb Reissue. This amp is in a head only cab.
The amp has a Classictone OT shown below. It has mutliple taps. Currently the two output jacks are connected to the 8 ohm tap. One output jack is a shorted jack, the other is a standard output jack.
The goal is to modify this so that one jack is on the 4 ohm tap and the other jack is on the 8 ohm tap.
I am thinking we do not want a shorted jack in this scenario as we do not want to have one of the taps shorted, right?
Also what about the NFB? It is the gray wire I believe in the pics. Will it only be connected to one of the jacks + side? Does it matter which OT tap has the NFB connection?
Or, would it be smarter to only have one jack and install a selector switch?
Thank you, MarkO
Thank you, MarkO
