Accoustics 370 need help to for wiring the power card
  • Accoustics 370 need help to for wiring the power card
    I restore an old Acoustics 370. When i have received this, the power card was not connected.
    Red wire: Capacitor 7800uf
    Black wire: Capacitor 7800 uf
    Red wire: Preamplifier card
    Green wire: Preamplifier card
    Black wire: Preamplifier card
    White wire: Capacitor 3900uf
    Black wire: Output speaker
    Does a member can send me a sketch or picture on the right connection ?
    Thank for your help
    Not sure where you are located, but here is the service manual for the 370. Doesn't look like the leads from the power cable connect directly to the power board. The lines come into the auxiliary AC receptacle and then on to the power switch and transformer.
      Hi,
      i'm working with this manual. The problem is how to connect the DC part to the Power Amplifier Card.
      Thank
        Gotcha. I misread your original post. Here's a pic of the wiring of the card of a 370 I have in the shop right now. The top red leads are the high voltage coming from the main filter stage and the black at the bottom is the negative lead from the same can
