I have an Ampeg PF 500 bass head with the fault light on. I’ve read several posts on here about repairs of this board, which is pretty complicated due to it design and construction. Easiest would be to buy the replacement board from Ampeg, but due to supply issues they are out of stock.
I have a mad idea to Frankenstein the main board (which is a power supply and power amp combo) with one of these:
https://www.ebay.com/itm/354298126108
here are the schematics that I have for the PF 500
Ampeg PF500 Preamp.pdf
Ampeg Pflx 500 pwr amp.pdf
I do not have the output board schematic.
The eBay board can supply the correct voltage to the preamp board. I think I can figure out the other connections. The one big question is the 52 volt mentioned from the main board to the preamp. I’m not sure I can get that to happen. Any thoughts on what the 52 volt does thru the pre amp? Overall, is this viable? I only have $25 into the PF 500 as I bought it DOA as a project. Worst case is to flip it to EBay for someone else to play with it.
