I have an Ampeg reissue from the early 2000's, has 2 6L6 and three preamp tubes, 60 watts, master volume......When I first turn on the amp it has a normal volume, the gain and volume controls work normally...but after a few minutes, there is a sudden reduction in volume and the gain control seems to no longer effect the volume or the amount of gain, so I have to turn the master volume up to reach the volume level that the amp had prior to the volume reduction. It seems like after the amp heats up something goes haywire, reducing volume....one of the preamp tubes? Also, it seems that just before the volume reduction there is a kind of click sound, like a switch kicked in..This volume issue repeats whenever the amp cools down and it's turned on again...Any help appreciated.
Ampeg reissue R12R issues - sudden volume loss
Do you mean two 6L6 ?
Like schematic attached?Attached FilesOriginally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Is it doing the same as if you were engaging the clean setting with footswitch? Are you using a footswitch? If not, have you cleaned the footswitch jack?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostIs it doing the same as if you were engaging the clean setting with footswitch? Are you using a footswitch? If not, have you cleaned the footswitch jack?
If not using footswitch, try the channel switch. Does clean channel work normally?
What is the difference between clean channel, and when fault occurs with drive channel?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostIf not using footswitch, try the channel switch. Does clean channel work normally?
There is a diode, D11, across the relay coils. Measure the DC voltage across D11 (one meter probe to each end) with amp switched to 'dirt' channel. Does voltage stay the same when working right as when fault occurs, or does voltage change?Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostThere is a diode, D11, across the relay coils. Measure the DC voltage across D11 (one meter probe to each end) with amp switched to 'dirt' channel. Does voltage stay the same when working right as when fault occurs, or does voltage change?
It's just verifying some of the voltages listed on the schematic for the switching circuit. I thought that would be easier to describe if you do not read schematics.
The tech can verify if the K1 relay that switches the gain pot in and out is getting it's appropriate control voltage. It may be, and the relay is defective. Or it may be getting an improper command from a defective relay control circuit.
One other thing you could try is tapping on the K1 relay when the fault occurs and see if the proper volume comes back.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
Originally posted by g1 View PostIt's just verifying some of the voltages listed on the schematic for the switching circuit. I thought that would be easier to describe if you do not read schematics.
Originally posted by ctone View Postbut to test the D11 diode, I turn the amp on, put the channel on clean, test, then switch the amp to gain, test....compare readings......
Originally posted by g1 View PostI'm more concerned with the amp in gain channel. Does the D11 voltage in gain mode change from when working correct (cold) to when the fault occurs?
It's possible that there is a bad solder connection in the area you are probing. You may have temporarily restored the bad connection.Originally posted by EnzoI have a sign in my shop that says, "Never think up reasons not to check something."
