I can’t be the only one to have come across this..
amp came in with blown HT fuses. Replaced em. Biased up fine. No bias irregularities or drifting etc.
what it does have is annoying static / crackling sound i generally associate with bad solder joints, tubes, plate resistors, transistors, etc.
I can only detect the noise with audio probe and scope between the plate resistors, and the power tube grids.
After trying different tubes, I’ve reflowed all of the solder connections in this area, tried replacing plate resistors, C84 and even C41 as it got damaged while I was trying to heat cycle the area with a heat gun, which was making the noise go away….
however freeze spraying certain areas after the heat has not narrowed it down any further… it’s pretty well narrowed down as is.. which is driving me nuts that I still can’t figure it out…
pulled board again, Reflowed more solder joints..
still makes the noise… chop sticked everything…
anyone else come across this?
Had to step away as I don’t even know what else to try or look for. Ugh!
Kicking my ass!
Kicking my ass!
