I have a mid-90's Mesa Heartbreaker getting a full recap, and I have a question about one capacitor in the 12 volt supply for the footswitch. On the schematic, it shows two capacitors, and the only value shown is 1kuf@25V. On the board are two caps, the second one after the 100 Ohm resistor is the 1Kuf value, the first cap closer to the transformer is 150uf@100V. Interesting thing is the board has silkscreened identifiers and the slot is labelled 150uf@100V.
Has anyone seen this before? Is this a misprint at the factory? It just seems odd to drop the capacitance by almost a factor of ten, and at the same time spec'ing a 100V cap for a 12V system. Something seems off there. Should I trust the schematic, or what came stuffed and silkscreened on the board? (The current owner acquired the amp "blown up" so nobody knows if the system worked correctly when the amp was previously functioning.)
Similar but somewhat unrelated question, same amp, same schematic page, in the filament supply section. The schematic calls for a whole bunch of 6.8K@10V capacitors. The amp came with 6.8K@6.3 V caps. Now, doesn't a cap going across from +3V to -3V see 6V in operating range? Wouldn't that mean that under no stress normal operating conditions those caps are being run at nearly full rating? Or am I not doing the math right?
Many thanks in advance to anyone who can shed a little light on this for me.
The schematic is attached. The power supply is on page 8. I apologize for the extra pages.
