I have this 400gh board confusing me. For starters, the amp would turn on with a loud buzz. I found a physically leaking C36 and C37, replaced them, and started it slow on the variac in which it blew the 1A fuses. I removed the regulators and no difference, the fuses start glowing hot. All the diodes check out, and when I remove them, the fuses stop glowing but now R32 and R30 start to smoke. Output board and Preamp boards are disconnected. As far as I can tell the 16v rails only go to Q16 and the rest go to the preamp and it appears the 15v and 16v rails are separated (with the exception of Q16). I obviously have something else going on with the rest of the circuit, but why is this "something" burning the 16v fuses when all the 16v loads are removed?
Note: I get good diode junctions on both Q6 and Q7.
Schematic link: https://music-electronics-forum.com/...etch?id=868215
