Behringer Europower pmp1680s noise on top of signal
  • Behringer Europower pmp1680s noise on top of signal
    i have a Behringer Europower pmp1680s noise on top of signal Its weird included video.
    There is no DC on the outputs.
    I'm thinking filtering from the power supply but not sure.
    nosaj
    What sort of noise ... hum ... hiss ... parasitic?
    I don't allow the gargler to use my information so won't even bother to try and open your link.
      Almost sounds like hash , sounds digital . I'll see if I can get a scope picture. Reason I used google drive was video was 9.8megs max upload limit here is 9megs.
      nosaj
        Service manual
        nosaj
        P0A8M_service_PMP1680S_P0A8M_Service_Manual_RevF.pdf
ID:	979363 Here is a pic
            Where are you looking to see the noise?
            Can you trace it back before the power amps?
            Can you pin point the source?
            Yes, it could be a noisy rail.
              I'm finding it on all outputs(monitor out, FX out, tape out).
              IDK if I'm overlooking it or what but I'm not seeing the power supply section in the service manual.
              nosaj
                Power supply is SMPS u29
                SMPS U29.pdf
                nosaj
                  Looks like the power section is also missing from that service manual too.
                  nosaj
