Ok gents....Mesa Maverick time .....
Amp has a low freq hum and a buzz , depending on settings . I took a bunch of notes so here we go . This is going to be a long one.
boogie_maverick.pdf
In Rhythm mode = Output Level on 0 , hum , switch to Lead mode it turns into a Buzz on 0 without the hum
If Out level is turned up the hum re-appears along with a buzz (lead mode)
Pulling the PI tube kills all the noise, both channels .
Bias is perfect , not finding any odd voltages anywhere in the amp (yet)
no DC on v1 or v4 grids
no Dc on input jack
swapped all pre tubes . New el84 sovteks . output tube pcb looks good as do the resistors on it .
Chop-sticked the amp
Hit everything with Freeze spray
It has all the original caps. I did clip on the appropriate cap across each of the HV caps , 1 at a time . There are 5 or 6 30uf , and 2 220uf . No change at all with hum .
There are 2 radials that are not on the scem? a 1000uf/25v and a 150uf/100v. the 1k looks like the coating shrunk down due to being right next to the 10w bias resistor im guessing. I have ordered those 2 caps .
Theres also 2 diodes right in that area that i dont see on the scem. 1 has 63vdc at it and its getting to 130 degrees--is that excessive ?? Not sure where its going..trace is under pcb.
running the laser temp gun around i also see that 1 LDR is getting to 118 degrees. Too hot ? which Ldr? I dont know thanks to Mesa not labeling the pcb . I can try and trace that one if needed .
So , any advice would be great...i understand if you run far away ( Mesa)
boogie_maverick.pdf
no Dc on input jack
