I have a triple rec on the bench with the complaint of loss of low end, thinner and overall output loss. All tubes test good in my hickock. Filters pass the ESR check. 6L6GC's bias around 31mA at 432V or ~46% dissipation. Screen resistors are good. Customer has everything in diode rectifier mode and "bold".
When running through my 8 ohm dummy load I am looking at 1.8A idle current and I can only get around 50W out of it at 3A , at 4ohms we are looking at 70W at 3A. My variac fuse is only 3A so I have to stop there for now, but this seems like low output watts for the current draw, especially with the mains fuse at 4A and the amp supposed to be 150W. There is certainly plenty of tubes in this thing, but I don't work on these enough to know for sure. Thoughts?
