Original issue was excessive hum. I changed the filter caps and wondered if changing C37 was necessary. There was still hum and I had the cap so I did. When I tested the amp, it would develop a steady thump after about 20 minutes. Similar to a vibrato tick but a deep tone. Complicating matters is the boss had me install the Moyer mods a year ago. At the time of completion, everything worked.
Sometimes I turn the amp on and there is no thump. The next time I turn it on, it's back. If I turn the intensity on full, the thumping stops until I turn it back down. The first time I tested the amp, the vibrato worked even with the thumping, but now it never works. Reverb does work however.
Here are some readings
A.C. in 119.5 vac
B+ 422 vdc
Z. 422 vdc
Y. 348 vdc
X 294 vdc
V8 3. 419V 4. 421v 5. -39v
V7 3. 420V 4. 421v 5. -39v
V6 1. 259V 2. 15V 3. 23v 6. 252v 7. 16V 8. 23v
V5 401v 0V 0V 420V 400V 23v
V4. 210V. 0V. 01v 421v. 400V 0V
V3 420V 0V. 03v 419V 0V. 03v
V2 195V. 0V. 01v. 182v 0v. 01v
V1. 196V. 0V. 01v. 160V. 0V. 01v
I hope this is intelligible. I got tired of fighting the auto correct.
Fender-Custom-Vibrolux-Reverb-Reissue-Schematic.pdf
Custom_Vibrolux_Reverb_Moyer_Mods.pdf
Well I can see my neat columns did not translate. From V6 to V1 it is always pins 1,2,3,6,7,8.
A.C. in 119.5 vac
B+ 422 vdc
Z. 422 vdc
Y. 348 vdc
X 294 vdc
