Bunch of questions on filtering and voltages.
I want to replace all the original filter caps on an old mono audio tube amp. The amp has caps in series with balancing resistors. Voltage rating doubles in series, I assume this is why they did this.
I wonder why not use a single capacitor instead without the balancing resistors?
Example
replace (2) 40 uF @ 450V in series with (1) 22 uF @ 550V
replace (2) 20 uF @ 350V in series with (1) 10 uF @ 550V
Currently there is 500V at the first filter cap. The amp calls for a pair of KT-66 but has a pair of 6L6GC tubes and there is 470V at the plates.
I am wondering if it is a good idea to lower the high V with a dropping resistor, and if so what value and where to place it?
Schematic attached. Thank you
Example
