I serviced an Airline Model 62-9012A Amp made by Danelectro (Same as Silvertone 1471) all tube combo, properly installed a 3 prong cord as I have done 100 times prior.
I tested the amp for AC on the chassis and there was none.
I shipped the amp to someone and they say they are getting a bad shock from the amp.
I am wondering what else could cause this to happen.
I would have installed the HOT to the fuse, switch, and PT. The neutral direct to the other side of the PT. The ground to chassis. If there was a death cap, I would have removed it.
Any ideas?
The amp has a power transformer. Tube line up 6X4, 6V6 12AX7. Very much like a Silvertone 1471.
Could not find an exact schematic but something like the attached image.
Thank you
Any ideas?
Thank you
