Have a Peavey 5150 60w combo, going into a weber mass attenuator, then line out to effects return on a Marshall 1987X, then into a 4 x 12 cab.
Delema = with weber line out volume almost off the volume is at about 95db, which is fine, however as the amps are being played the volume starts increasing and about 10 min later it is up to 100db.
What would / could be causing this volume increase to occur?
weber set to 16 ohm / peavey combo speakers checked out to be 13.8 ohm
4 x 12 cab checked out at 14.4 ohm, however the speakers on the combo are disconnected and running that amp output into the weber.
Thanks, Dazzlindino
Thanks, Dazzlindino
