Hartke HA-3500 static noise. Traced to output board thus far.
  • #61
    Now that looks better but likely somewhat low (by 0.5V or so).
    I guess both pot wipers have lost contact to the trace.
    I have them both turned all the way down since I couldn’t tell what the bias was.
    so I just checked the good amp across test points and was able to adjust the bias up to 25mv. Which seems to be ok for these.
    no clue why I couldn’t get readings there before.. but anyway.
    the bad amp still has 0.0v across test points. I’m suspecting SVR302 on that amp is also bad.
