Seismic Audio Plate Amp no drive
  • Seismic Audio Plate Amp no drive
    Subwoofer section had blown outputs and drivers plus burned traces on the power supply board. I replaced and repaired everything, but subbed mje15032/33's for the driver/predrivers. The signal looks good until a load is hooked up and then it collapses and never attempts to draw any current. I've checked all my emmiter and base resistors, I have no DC offset, the opamp has been replaced, bias transistor replaced. I'm starting to think these mje's are just different enough to keep the amp from working. What am I missing?
    With scope attached at the amp output,
    No speaker load:
    Click image for larger version  Name:	20230425_112323.jpg Views:	4 Size:	4.96 MB ID:	981358
    With Speaker load:
    Click image for larger version  Name:	20230425_112352.jpg Views:	0 Size:	5.05 MB ID:	981360
    Are the current limiters OK?
Name:	Screenshot 2023-04-25 at 19.20.51.png
ID:	981366 If they are short ciruit, quite likely from the described carnage, you will have no current to drive the output transistors.
      MJE15032/33 for 2SA940 and 2SC2073 ? They look close enough to me.
      Does the bias adjust pot change the voltage across emitter resistors of output devices?
        Welp... this was it. Sure enough, they show shorted. I was positive I checked these and at one point I even desoldered the emitters just to rule them out. I removed them from circuit and voila... wattage.
          Don't forget to replace them ... or ... didn't they work?
          Whoops!
          Another not so good design that failed in a spectacular way
          Joking asside, pleased to help.
            I replaced them and amp is back together. Sometimes a man just need another set of eyes to get his mind back in line. Much appreciated.
