So the store sold and shipped this amp only for the customer to have an issue with it (don't remember the original problem), and their tech told them it had bias drift. The amp was refunded and sent back, and my task is to check that it does in fact have bias drift. So I installed my two plate current probes on the outer tubes played it for a few mins, unplugged the guitar and let it set for 5. I then started a timer and took bias readings for an hour at 15 min intervals. Next I put a signal through it at 10W and took readings again. Here are my results. Initially there appeared to be some drift but was surprised how steady the bias was while playing it through a dummy load. I guess I expected it to drift while being played as well. Obviously these tubes are not very well matched but thoughts on readings and if you think it has bias drift? Any changes to my test setup? I was going to test the inner tubes tomorrow to see if I get a different result.
Idle
00: 43.4, 25.7
15: 42.1, 27.0
30: 41.5, 28.4
45: 41.2, 29.4
60: 41.0, 30.0
@10 W
00: 42.5, 38.6
15: 42.4, 40.0
30: 42.3, 40.2
45: 42.5, 40.4
60: 42.2, 39.6
Idle
00: 43.4, 25.7
15: 42.1, 27.0
30: 41.5, 28.4
45: 41.2, 29.4
60: 41.0, 30.0
@10 W
00: 42.5, 38.6
15: 42.4, 40.0
30: 42.3, 40.2
45: 42.5, 40.4
60: 42.2, 39.6
