Hi all, first post here and its a bit of a doozy.
I had a LOUD Tech era SVT-CL Classic come to me with the owner complaining of bias issues. Replaced a blown screen resistor, reworked all the output tube socket solder pads, did the same for the ribbon cable solder pads on the power amp board and output tube board. Amp bias is fine now.
Fired it up for the first time to be met by loud buzzing. Large filter caps all looked dodgy (some dented, some swelling, some both), replaced them all, buzz gone.
Now, as I continue to work through layers of problems with this amp, a third problem is revealed. It turns on and comes out of stand by just fine, but no signal passes from the input to the output, instead all you get is a low but very present hum, sounds sorta like 60 cycle with an occasional single popping noise. I traced a signal through the preamp and found that it drops out at C6. The upstream side of the cap has signal, the other side (going directly to V2:A pin 2) does not. Replaced the cap to no avail. Tried new 12ax7s no not avail, in fact the humming continues whether or not tubes are installed.
other interesting points of note:
-The best schematics I have been able to find seems to have some minor discrepancies between it and the actual circuit I'm working with. Admittedly they are noted as being for an SVT-2PRO. Close enough for jazz but certainly introduces a healthy bit of uncertainty.
- With a signal introduced at the amp's input, sound flows through the circuit as soon as the power is switched off. For a few seconds as the caps discharge the amps sounds like its working correctly but fades as voltage drains.
- Sending signal straight into the power amp in jack results in satisfactory performance. Slight bit of background hum but signal is amplified without issue and drowns the hum almost immediately.
- There is roughly -13v present at the junction of c26 and r33, the manual specifies that there should be 0.4v. No idea where that negative voltage is coming from but this seems like a real issue.
- The +/- 15v power supply shows a pretty significant ripple, replaced c24, c25, c26 and c27, ripple still there.
- The +660v power supply node feeding the output transformer center tap also has a severe ripple even after changing C15 and C16 for brand new caps. Ripple decreases as I check further along the power supply and more filter caps come into play.
-In the main power supply voltages after the first dropping resistor (R54) seem too far from spec for comfort. At C17 I see +538v, C19 is +380v, C20 is +391v. all of these measurements are about 40v higher than spec. C21 is +365v and C22 is +323v with are both lower readings than the manual specifies.
Some of this may be extraneous info, or even normal, but I've been chasing my tail on this amp so I figured I'd note this things that stood out to me in my investigation.
In researching issues with this amp, this forum seems to have the best info available and has already been invaluable. If anyone wants to roll their sleeves up and dive in on this one with me I'd be all ears and very appreciative. Thanks!
