Fender Frontman 25R DC on Output
  • Fender Frontman 25R DC on Output
    Schematic attached.
    Amp is buzzing and I am reading -25V DC on the output.
    I assume that the TDA1514A needs replacement but I could use advice on what to check, and other components that may need replacement.
    Thank you
    Frontman_25R_Schematic_653.pdf
    The TDA 1514 may very well be at fault.
    I would carefully remove it and see if the Vdc is gone.
    Another culprit could be D13.
      Check that you have correct +/- supply voltages at the supply pins of the TDA. Also at the op-amps in preamp section.
        TDA1514 & TDA1514A is the same as the NTE7118.
        I would desolder pin 5 and check the short ciruit is betwee pin 5 and pin 4, the negative rail.
        If it is still there, the chip is faulty.
          Supplies are good on all rails. TDA pin 3 is only reading -19 V, pin 6 is 26 V.
          Read - 26 V at R70 and D13
