i started a new topic to update my old misspelled topic on a crate 32 212 that had bad problems. the original owner said it would shut down while playing. in my experience it would start making crazy startrek noises at loud volumes.... i attempted to read the bias on the 4 el84 tubes and found that the tubes were dissipating 17 watts per tube and that the b+ voltage was 345volts.
i have since started working on it again and i have placed a 50 ohm power resistor in series with the b+ line. that brought the b+ down to 314v, which is close to the 320 the schematic calls for. the amp stays on now and does not make any crazy noise(by ear)
could someone help me out with the bias procedure again?
the single bias resistor has a voltage drop of 11.22v and a resistance of 62.9...the schematic calls for a voltage drop of 10 volts btw. but is this close to the 12 watt mark that el84s are rated for? thanks everyone.
