Framus Ruby Riot 2 scratching and popping noise
  • Framus Ruby Riot 2 scratching and popping noise
    Framus Ruby Riot 2 has scratching and popping noise coming and going EVEN WHEN all 12ax7 removed and no instrument cable attached. I resoldered all the power tube sockets just in case, measured all the reisistors, everything looks fine, not even a dust, it's pretty new amp. I do not have spare EL84 at the moment though, will get them soon. In the mean time I would appriciate any suggestions what else to check...
    Most likely a power tube issue. I assume the noise stops with all EL84s removed?
    What is the cathode voltage?
    Does it make a difference when you disconnect C99?
      Yes, the noise stops when EL84's are removed,
      Cathode voltage is 13,2 vdc.
      The C99 is as I see a cathode bypass cap, it is really hard to disconnect, there is no space to cut one leg, needs to be unsoldered from the bottom, I would have to disassamble all the tube sockets in order to get the Power board out and deal with it. Is that info really important or I could just wait for the new tubes and try with them?
        Cathode voltage looks good.
        Let's wait for the new tubes.
          Just to confirm, it was the power tubes, after new ones are installed works perfectly for weeks now....
