Ampeg V4 VT22 Loud Noise in Preamp
  • Ampeg V4 VT22 Loud Noise in Preamp
    This V4 has a rough looking board, see pics. Is that corrosion around many of the solder points?
    The amp works well but suddenly emits a very loud buzz noise. Sometimes it can be controlled by the volume, and sometimes it is independent of the volume control.
    Using a chopstick I can recreate the problem by touching the preamp board in the V1 and V2 area. I can make the buzz come on and off by chop sticking.
    Any suggestions on how to cleanup the board and isolate the issue which I suspect is a bad connection?
    Thank you
    V1 is at the top of the first and third picture.. Note the large hole near the bottom of the board.
ID:	984302 Click image for larger version
ID:	984303 Click image for larger version
ID:	984301 Click image for larger version
    Have you tried cleaning the V1 & V2 sockets? Also closely inspect all the board mounted socket solder connections as they often need resoldering.
      I try to get the leftover flux off the board with alcohol and a toothbrush. That’s what you referred to as corrosion I think. Then when you go hitting those solder joints it ends up cleaner.
        Yes flux (corrosion in my mind). Can flux be conductive?
        I reflowed the 4 preamp tube pins on the board. Now I discovered a new problem. Very low output, and found only 19 VDC at pin 1 of the first two preamp tubes.
        There is a 68K R that drops the supply to pin 1. After shutting down I read about 2M R on it. Now I am on the top side of the board and took another reading and it is about 68K. I powered up without preamp tubes installed and measure about 320 V at pins 1. However if I plug the tubes in I am back down to 19 V. I suspect the 68K R is failing when under a load?
        I have swapped tubes around prior to checking this and had low output in all tests.
        I would attach a schematic but have not found one that is legible yet.
          Flux is not normally conductive.
          If the 68k connects to the plate (pin 1) it's not a supply dropper but the plate resistor.
          In any case measure the voltage drop across that resistor.
          If the input tube has a cathode bypass cap (at pin 3), disconnect it and see if voltages change.
          Does the noise stop when you pull the input tube?
            Noise is gone (for now) but I need to check again at proper V.
            There is about a 285 V drop across R13. See photo of schematic. No cathode bypass cap.
              Voltage drop across R13 should be only around 100V.
              What is the cathode voltage (pin 3)?
              Does the pin 1 voltage change when you vary the vol. pot VR 101?
              Also check R14.
                R13 reads 60K 306 V one side, 16 V other side
                R14 reads 3.4K only reading mV
                V1 pin 1 : 19 V
                V1 pin 3 : 114 mV
                V1 pin 6 : 184 V
                V1 pin 8 : 2 V
                V2 pin 1 : 18.7 V
                V2 pin 3 : 11 V
                V2 pin 6 : 184 V
                V2 pin 8 : 2 V
                  VR101 has no change on V
                    Replaced R13, no change
                    and again I am reading 2M R at each end of R13 on the bottom side of the board, and then a minute later I read 70K R
                      Check for a broken board trace (often close to an eyelet).
                        The reading is on the resistor leg itself (which I think would rule out the board), 306V on one side and now 6V on the other side.
                        Couple of better images of the schematic...
ID:	984330 Click image for larger version
                          and I have continuity from R13 to both V1 pin 1 and V2 pin 1.
                            Is the 2M reading measured on both resistor legs? Seems very unlikely with a new resistor provided your meter tips both made good contact.
                            A good resistor can't read higher when solderd in - except maybe if there's residual voltage in the circuit.
                            What are those voltages with V1 or V2 pulled?
                              No wonder as both pins 1 are connected. The 68k is a shared plate resistor.
