I have been working on an Ampeg SVT VR for a few weeks now and replaced the power tubes and all electrolytic caps and am waiting on the owner to buy new preamp/driver tubes also. After a complete teardown (and some muscle relaxers for my now wrenched back due to 85 pounds of beast on the bench) I did a quick power up. I had to go it on faith because my variac can't handle the current of this monster. Good news is, no smoke, bad news is I can't control the bias settings at all so my time powered on is as short as is possible as half the tubes start to red plate as the HV comes up. I'm hoping the new preamp/driver tubes will help.
Anyway, I also replaced the 220 ohm screen resistors and the 5 ohm resistors on the tube board. The 47.5k grid resistors all check good. Also I had to replace R24 on the preamp because it had changed to 9.3k.
When I powered it on first the Balance LED was lit and one Bias LED was lit. After a brief full power check and a quick sweep of the bias pots to try to kill the LEDs I noticed the ates of the new power tubes starting to heat up and I shut it down immediately. I haven't been able to leave it turned on for more than a few seconds since it tries to melt the tubes right away.
So then I got online and found this forum where I've found a possible treasure trove of information that I can't get to. I don't know if it's because I'm new here or what but throughout all the articles and forum posts there are countless links to documents and such but I can only access links to previous posts. While there are alot of similarities in the SVT-VR and CL they are not absolutely identical and I'm wary about variances in values and possible mods to fix things that make sense. For instance, the mod to insulate/isolate the 12v regulator. I just added 2 lock washers between each of the standoffs and the chassis. This lowers the heatsink away from the chassis so ground loops aren't possible. My experience is you never float anything especially a heatsink. Cutting foil runs and mica insulators and all that just gives you a piece of ungrounded metal inside and that's never good.
Anyway I'd love to write alot more but for now my main problem is the lack of documentation. The schematics found on bustedgear are incomplete and don't have the transformers, output board, or the ac-term board nor are there any layout drawings. It appears that nevetslab has posted numerous links to lots of pertinent information but none of them are accessible. Before I can really go any further and ask for help or whatever I'd like to have a look at the full schematics and drawings. Does anybody know when, if, or where I can get access to these documents as I have not been able to locate them anywhere else and there's links to the documents I'd like to look at here but I can't view or download them.
