Bugera 333XL Tube Head Issue
  • Bugera 333XL Tube Head Issue
    Hey Folks.
    Trying to repair a 333XL. It had a broken main fuse which I replaced. All tubes tested good. Now I am getting poor sound quality and sporadic volume output. To me it sounds like the voltages are off at the tubes.
    I have the schematic (attached) but it is missing voltages at the tubes. Unless it is there and I cannot find it.
    Anyone see it or have a better schematic? If not I can take readings at all the plates and post them.
    Also could not find the PS in the schematic or what value replacement main fuse to use. I inserted a 3 amp for now.
    Thank you, MC
    edit. this is a "infinium" version.
    bugera_333xl_sch.pdf
    Perhaps these voltage readings are not too bad.
    EL34, V1-V4
    V1 3. 444
    V1 4. 438
    V1 5. -38
    V1 6. 0.3
    V2 3. 444
    V2 4. 438
    V2 5. -37.4
    V2 6. 62 mv
    V3 3. 444
    V3 4. 438
    V3 5. -36
    V3 6. 0.5
    V4 3. 444
    V4 4. 438
    V4 5. -38
    V4 6. 0.5
    12AX7, V5 - V9
    V5 is the phase inverter
    V5 1. 312
    V5 6. 308
    V6 1. 214
    V6 6. 214
    V7 1. 202
    V7 6. 174
    V8 is the first preamp tube
    V8 1. 165
    V8 6. 143
      Schematic has PSU on pg.1. Shows 2A FB for mains (F1) (edit: wrong F1, not mains, see below)
      What do you get when you use the FX loop to isolate, preamp or poweramp problem?.
        Good suggestion on the FX loop.
        I feel like a dummy. I sprayed the heck out of the many pots, switches and jacks. Amp sounds fine now.
        Thank you, MC
          The 333 212 infinium (non-xl) shows 3A FB mains fuse. As neither schematic matches your unit, the fuse could be either. Possibly the owners manual will specify.
          (edit: error, not mains fuse)
            Manual states T 3.15 which is what I put in there. Crazy that the back panel does not list the fuse type.
              Are you sure it is the mains fuse?
              F1 on page one is the HT fuse.
              I'd be surprised to see a fast fuse on the mains side.
                There is an F1 on the main board which is not the mains fuse.
                  I had to cut and scrape the white stuff off the small PS board to remove the broken fuse holder and install an inline mains fuse.
                  Some pics that may be helpful in the future...
ID:	984951 Click image for larger version
ID:	984950 Click image for larger version
ID:	984948 Click image for larger version
                    You are correct. Attached is the drawing showing the mains fuse which matches post #6 (T3.15A)
