Got this pedal in a partial trade deal. The effect does not work and I wanted to start a topic on it as I go through it.
The on/off switch works. The power LED lights up.
Pressing the effect on/off switch creates a slight change in sound but there are no effects happening. I cannot even tell which position is ON vs OFF.
Here are some weird observations.
Power ON. Level pot works in either on/off effect switch position.
Power OFF. Level pot becomes a backwards volume control
Power ON. Blend knob is a backward volume control with effect on/off in one position, in the other position it does not.
The feedback, delay and chorus/vibrato pot do nothing.
The chorus - vibrato switch does nothing but seems to be operating properly as a switch verified at the switch and at the board.
The delay pot has had a resistor installed across the outer legs.
I am not sure of the exact board model as the designation on the board is written in pen and must have been written in an alien language.
I am attaching some pics and what I think may be the schematic.
The PS to the board reads -15.7 V.
Also a link I found that may be helpful to me and others... https://sites.google.com/a/davidmorr...ry-man/eh-7850
On both MN3005 chips I see
-16 V on pins 7 (good)
-10 V on pins 8 (schematic says it should be -15 V)
electro-harmonix_deluxe_memoryman_delay_sch.pdf
![Click image for larger version Name: IMG_20230811_100317244.jpg Views: 0 Size: 824.8 KB ID: 985031](filedata/fetch?id=985031&d=1691766935&type=medium)
![Click image for larger version Name: IMG_20230811_100420632.jpg Views: 0 Size: 2.20 MB ID: 985033](filedata/fetch?id=985033&d=1691766940&type=medium)
