I recently purchased a highly-hyped "anniversary" amp based on the 5F6A bassman, with a few differences such as three-inputs (clean/lead/both) and reverb on the "clean" channel.
Yeah, I know, I shouldn't have fallen for the hype.
The first preamp tube is a 12AX7 (unlike the original bassman's 12AY7) and seems to be setup to prefer single coil pickups. My guitars being all HB or P90 based, this has caused a problem where the input seems overloaded, notes feeling very compressed or "squashed". Since this is a 45-watt amp, I expect a LOT more volume before getting the compression I'm seeing at 4 or so on the volume knobs.
I sent a note to the builder asking about this and here is his response:
"Regarding the amp question, let me say this: When you play a Mel Bay "cowboy E" chord with a single-coil strat pickup, the guitar's output is 1/8 of a volt. Do the same chord with a humbucking pickup and the output is 1/4 of a volt - about double. But play the same chord on a P-90 pickup and the voltage is 1/2 volt - four times as much as a strat. So, if you are going for clean tones, you can't get it without either: 1. Turning the volume of the guitar WAY down, but when you do, you will lose highs, so a small compensating cap on the volume control of the guitar will help ( use a 500 pf value)
2. Change the first gain stage tube to a lower gain version. Since the P-90, is four times the gain of the strat pickup, a tube with a fourth of the gain of a 12AX7 will work nicely. 12AX7 has an amplification factor of 100, so you need about 25. A 12AU7A is a factor of 20, which will do the best. Or you could try a 12AY7 and then bump the guitar volume down just a "C" -hair"
Does this make sense, or would a change to the circuit be more in order?
Thanks in advance!
Thanks in advance!
